2359glenn
Member of the Trade
- Aug 16, 2010
Glenn,
There is an adapter on eBay allowing the use of two 6BL7 in one 6AS7 socket.
http://www.ebay.com/itm/1pc-Dual-Gold-plated-6BL7-TO-6AS7-tube-converter-adapter-/191792226144
What do you think?
When I build the OTL to use 6BL7s it uses 3 per channel. But 2 mite work fine the 6BL7 is a good sounding tube.
I told the people on the ELISE thread to try this and they had this adapter made.
Just got the two EL3N to 6SN7 adapter today from the same place and it works fine.
I would say try it if it works out the 6BL7 is a great sounding tube with HD800s.
