Silent One
What silence said... then nothing.
- Aug 9, 2010
It may have taken a few hours and a few hundreds miles but the aroma from Clayton's plate just hit me wirelessly!
Excellent!
This plate is only a small portion of what I actually ate. Sampling while cooking does that.
You and Steven should not be showing me pictures of food............
I had breakfast but I am hungry now!!!!!!!!!!!!!!
My pigtails work just fine for the HiFiMAN HE-6... a-l-l n-i-g-h-t. What are y'all afraid of overseas?
I've had mine leashed to more than the Aleph running the HE-6, but I have yet to test the T1 using them.
Sounds like a plan for tomorrow.
But... it is tomorrow.We wanna know. And granted, I watch the volume but yeah, I routinely push through 265 watts per channel!
I think you two are crazy..............
The resistors is to protect you from yourself. Without the resistors there is nothing stopping you
from turning the volume up and blowing your headphones.
I suppose if you have self control you can hook the headphones up direct it will sound better. But if
you leave the volume turned up and feed signal into the amp. Buy buy headphones and maybe your ears.
Plus on a tube amp with a output transformer it should have the proper load or the output transformer can arc over.
