rosgr63
Fine because the amp is using two 6SJ7 which are like one 6SN7.
The 6SJ7 is 1/2 a 6SN7.
Glenn's OTL's, SinglePower and others that use one 6SN7 driver need a tween type adapter.
Glenn, our friend sent me 2 beautiful flat plate 6BL7's amongst the other nice tubes so I am fine.
I am very pleased to know you are helping me cure my addiction by introducing me to more tubes!!!!!!!!
Stavros, the Lafigaro 339 uses two 6AS7 power tubes and 2 6J4P input tubes. The 6SJ7/5693 are direct replacements. I alreadu use EF80 with an adapter as input tube and now we want to try the C3G as replacement. There are no 6SN7 involved at all.
Ok?
Stavros when I get caught up I will make you a twin C3g adapter that will work
in your OTL amps.
First I have to find one more 6BL7 flat plate. I have three when I get four I will send them
and you will have all six and be able to try them.
