Clayton SF
- Aug 27, 2009
That is so true. I own 4 Mullard EL34 tubes and 2 test bad, 1 tests very week, and another tests very strong on the 4 tube testers I own. Surprisingly they still sound incredible in my power amp. I reported this to Bob Putnak and he said to just keep using the Mullards until they don't sound good anymore. And that was 2 years ago. They still test the same and they still sound incredibly good. -- Go figure.
Here is some excellent advice from Bob Putnak
In reality, regardless of tube tester, you will find a number of tubes that PASS your tube tester(s) and work SUBSTANDARD (or outright fail) IN-CIRCUIT, and you will find that many tubes you REJECT as "bad" or "weak" would work FINE in circuit if you had actually tried them. That will ALWAYS be a FACT.
