Thanks all
It will actually be a single-ended triode design, so maybe I will call it the LGSET? LSET? Haven't given it much thought lol. The amp will definitely have Glenn's fingerprints on it since much of the design will come from his amps, not to mention he is helping me with the schematic. Hopefully people don't mind if I post here as sort of a build log, still relevant to the thread I think! Many of the components for the amplifier circuit have already been chosen, so that part is relatively straightforward and the schematic is probably mostly done already. What I need to work on is the power supply, will have some variation of a tube-rectified CLC design. I have to decide what I am going to do with the driver tube filaments, whether it is filtered DC or lifting them off ground, etc.
Going to cost me a pretty penny to get started, here is my shopping list so far not including circuit components:
Drill press - been working with a hand drill so far, but that won't cut it for this build (no pun intended)
Dim bulb tester - I could build this myself, but I'll probably just buy one
Isolation transformer - have been considering one of these to isolate my system from the wall outlet, so I'll be killing two birds with one stone!
Digital oscilloscope - for measuring frequency response, power output, FFT function for eyeballing distortion profile
Signal generator - sine wave and square wave analysis
Optional:
Keithley 2015 DMM and distortion analyzer - I definitely don't need this, especially since Glenn has already done some distortion analysis with the E424 tubes in his preamp. BUT man, I really do want one. With a low distortion input signal, it can measure THD down to 0.001%, which is plenty low for a tube amp. This way, I could see how changing components affects THD and optimize the tube bias. Could also measure how different tube loadouts affect the distortion. They are expensive though, around $600 on the used market. I think long-term it would be a very useful tool to have. Don't have to decide right now, we will see...
I already have a variac, tube tester, and other building materials. Also making my way through two books by Morgan Jones,
Valve Amplifiers (circuit design focused) and
Building Valve Amplifiers (practical building and testing focused).
