Phantaminum
What temp are you guys using to heat up the pins? Bottom of the pins? side of the pins? All the pins? Inquiring minds would like to know.
I’ll add the soldering iron make and model this evening and what temps I’m using.
For the method - I hold the tube upright with the pins facing down, move the soldering iron on the pins (I put the iron on the side of the pin that’s easily accessible) up and down each second for about 30 - 40 seconds and go all the way around. Never put the soldering iron at the bottom of the pin since that does contain solder and you don’t want to remove it.
I’ve got maybe 75% of the tubes fixed this way or with a second go around.
