2359glenn
Member of the Trade
- Aug 16, 2010
No,no resistors. Its the same design as Ken's,just has screws as opposed to glue.
Good no inferno inside the adapter.
Were the Chinese adapter makers go wrong is if you do the math it has to dissipate 4 watts of heat so they put two 2 watt resistors in series to fit in the adapter .
In order to dissipate 4 watts you need a 8 to 10 watt resistor and that won't fit in the adapter,
They don't care if it lasts a couple of months it's all good. That also cooks the glue at the base of the tube.
