This is the build I'm going for, and haven't changed my mind since coming up with the 6J5 + 6V6/EL34/KT66/KT77 idea. My only question to
@2359glenn is 4 6V6/EL34/KT66/KT77 or 2 6V6/EL34/KT66/KT77, and whether it would be worthwhile to have a 6V6/EL34/KT66/KT77 selection switch?
They all use the same impedance output transformer.
Guess could switch for the different cathode resistors Kt77 470 ohm KT66 500 ohm EL34 130 ohm 6V6 180 ohm.
This way they will all be operating at optimum operating point.
Leftside your amp is very similar to the one I'm getting. But mine will use a single 6SN7 driver, along with a 1-2 stage knob and output impedance knob for speakers. Personally I'm going with 4x power sockets allowing me to choose either 2x or 4x depending on what sounds best, which I'm thankful for Glenn agreeing to.
Here are the power tubes I plan to use:
(including with adapters)
EL3N, EL12, EL12 Spez, EL32, EL34, EL38, EL39, 6V6, KT66, KT77
@2359glenn would it be possible to also add a knob to switch the cathode resistor settings to allow all the above power tubes to operate optimally? Granted it would not be practical to have 10 different settings, so perhaps would you be able to let me switch between... say the top 3-4 'main' operating points? For example 1 setting for 500ohm for KT66 and KT77 since they're close, 1 setting for EL12, 1 setting for EL 38/39 and 1 setting for EL3N. Those are the most important to me and the others I can make do with between those 3-4 settings. Unless of course you have a better recommendation for the average resistor switch ohm values and number of switch positions based upon the above list.
However, would 4 knobs be too impractical for you to build? The resistor switch knob in addition to volume, 1-2 stage and output impedance knob. I'm really interested in this configuration and I'm willing to pay even more or have an even larger chassis if necessary, so please let me know. And this should be my final revision for this request.
Finally RE the CCS. I'm assuming this is for the driver tubes right? And if I understand correctly this should allow 6SN7, 6N7 and dual 6J5 (with adapters) and most miniature 9-pin novals to operate optimally; but would there be any recommended adjustment option for EL11 and EL32 to operate optimally as drivers?
