gibosi
- Oct 18, 2012
Thanks! But I still think it would be a good idea to have a "sticky" somewhere so I don't have to try to remember where I saved it. lol
Good idea - now in my signatureWould you be willing to put a link to this doc in your signature? Otherwise, I have no idea how to find it....
From my personal taste and experience, paying more does NOT guarantee getting more / better!
Many times I preferred the cheaper amp or headphone...
Words that can’t ring any truer.
I’ve started a journey looking for a specific sound. I have two stops which is the Teton and another amp.
If they don’t work out then I’ve decided that I have all I need.
One of @L0rdGwyn's 7802's tubes was acting up, so I had to smack it around!
Now it's behaving gloriously.
I have just reported you to TPS (Tube Protective Services)!One of @L0rdGwyn's 7802's tubes was acting up, so I had to smack it around!
I have just reported you to TBS (Tube Protective Services)!
I was looking at a Telefunken RGN4004 this morning. Looks similar to your rectifier with mesh plates. Can the RGN4004 be used in the GEL3N and if so, with what adapter?
Glenn, I will be using the 3DG4. It has the lowest voltage drop. So keep a shiny looking one for me.
