mordy
- Aug 8, 2010
Hi LG,That is great attention to detail, probably one reason you build fantastic amps.
All this pin-cleaning talk is due to a noisy Osram L63 I have, trying to avoid a return to the UK. Cleaning the pins with Deoxit, sandpaper, and IPA hasn't fixed the issue. It seems to be picking up noise from the amp since it is positional. If I rotate Deyan's adapter, the noise gets louder and softer as it moves, a sweet spot will fix the issue temporarily, but it comes back.
Anyone ever cured a tube that picked up interference? Using low-gain power tubes makes it tolerable. Otherwise, they sound fantastic.
I have a Valvo EL12 that picked up a lot of interference. I found an inelegant solution by making a Faraday cage around it. In practice it meant taking a piece of aluminum foil and wrapping it loosely around the tube. Somehow turning the foil around the tube and finding a suitable position, I could diminish the interference.
