2359glenn | studio
Aug 15, 2019 at 11:11 AM Post #28,621 of 39,983
not having to worry about the side contact bases
Question to @whirlwind and others who have GEL3N experience:
Are the side contacts a reason for concern, if upgrading the sockets to Yamamoto and NOT planning on tube rolling with this beauty?
Aug 15, 2019 at 11:11 AM Post #28,622 of 39,983
Speaking of adapters, on the chance that I am not the only one running AZ4 and AZ12 rectifiers in a Glenn amp, Deyan can make a very nice adapter to take advantage of the amp's native support for the 3DG4. That is, there is no need to worry about power resisters to reduce 5 volts down to 4.
That and I have a prototype EL11 to EL3 on the way made on request by @UntilThen
I'll upload a picture of the concept in about an hour.
Aug 15, 2019 at 11:15 AM Post #28,623 of 39,983
@rosgr63 sent me a mouse ear. It sounds good,but it wont make you want to take out your BGRP.
Actually this humble type is on of my favourite 6SN7's.
The black plates are the best sounding ones.
Aug 15, 2019 at 12:24 PM Post #28,624 of 39,983
New adapter day ( again )
EL11 to EL3
Don't mind the broken socket on top, it's only a test fit.
Aug 15, 2019 at 1:53 PM Post #28,625 of 39,983
Giving the 7802s a break and trying a new roll, Sylvania 6BL7GT T-plate. These are some good sounding tubes! But then I ask myself, aren't they all in the GOTL? Just different flavors of good/great/amazing/life-altering.
The MOV L63 are sticking around. Definitely one of my best drivers, haven't done a head-to-head with the other heavyweight 6J5s yet, looking forward to it at some point. The Visseaux 6J5G might make them sweat a little bit.
Aug 15, 2019 at 2:26 PM Post #28,626 of 39,983
Anyway I did a google and I saw @leftside have so many Triotron ECC32, ECC33, ECC34 and GZ34 metal base. :scream:
Triotron was the brand name for tubes manufactured by Radiowerk E. Schrack, Vienna, starting in about 1926. However, in 1939, Philips acquired control of Schrack and Triotron and changed the name to Wiener Radio Works (WIRAG).
Google is pretty sketchy, but it appears that Philips continued to use the Triotron brand in Britain, but only as a distributor, not a manufacturer. So there is no way to know for sure who manufactured these later Triotron tubes, but since the brand was owned by Philips, I think it is likely that those EL11 were manufactured by a Philips subsidiary. But until you have them in your hands and examine them closely, you won't know for sure.
All of my Triotron branded tubes are Mullards. @gibosi covers the company well. Further details can be found here:
www.cast.uni-linz.ac.at/Department/Publications/2015/2015_1.doc
Aug 15, 2019 at 2:27 PM Post #28,627 of 39,983
Give them a few hours, they might calm down. They are very old tubes.
Aug 15, 2019 at 4:44 PM Post #28,628 of 39,983
No worries at all as long as you get the Yamamoto sockets...I would in no way get the Chinese sockets...I don't think Glenn will even use anything but Yamamoto in the GEL3N amp.
Speaking of adapters, Deyan's adapters arrived today....man what a killer job you did on these Deyan.... thanks much sir!
Great snug fit and they sit nice and low on the chassis.....first round of tubes should be here next week some time.
Mullard EL34 XF2's single top getters from 1973.
Aug 15, 2019 at 4:52 PM Post #28,629 of 39,983
Thanks Ken. Always good to know the history.
Aug 15, 2019 at 5:02 PM Post #28,630 of 39,983
EL11 to EL3
Deyan, great work as usual. You're a master of the craft.
It's look like I'm going with Y8A Pin tube sockets for the EL11, etc. So later on, I might need EL3N to EL11 adapters and EL34 to EL11 adapters.... if I feel the need to experiment.
However, I'm sure you'll find some interest in these EL11 to EL3 adapters amongst the owners of GEL3N amps.
Aug 15, 2019 at 5:08 PM Post #28,631 of 39,983
Beautiful. Even a fussy pot like me can accept that. :)
Waiting to hear how the Mullard EL34 will sound in your amp.
Aug 15, 2019 at 5:39 PM Post #28,633 of 39,983
I had Deyan make me one of these adapters also...making it to the 3DG4 and the amps native support makes my mind much more at ease :)
Aug 15, 2019 at 5:41 PM Post #28,634 of 39,983
I can be a fussy old pot also.....my wife can VERIFY!
