attmci
Wait, which amp are you planning to use these tubes? Just curious.Electrically identical does not mean "sound" identical. All 6SN7GT are electrically identical, but an RCA sounds very different than a Sylvania. The factory matters.
The EL11 and EL3N are electrically identical. But of course an EL11 manufactured by Telefunken sounds different than an EL3N manufactured by Philips in Holland. However, it is relatively easy to remove the German octal base from a Telefunken EL11 and install a European side-contact base. And voila, you have a Telefunken EL3N. And in fact, you could even install an American octal base, but I have no idea what you would call it. And it is certainly possible to install a German octal base or a European side-contact base on a 6SN7GT! Again, the base has no affect on the sound. The tube will sound the same regardless of which base is installed.
As I recall, Telefunken strongly championed the German octal base and as a result, it became a de facto standard in Germany. But the rest of Europe primarily used the side-contact base. Some manufacturers and factories that served both markets manufactured both the EL11 and EL3N. And again, same tube, different base.
And this is not the only example of same tube, different bases. The AZ4 rectifier has a European side-contact base while the AZ12 has the German octal base. But again, they are identical except for the base.
What I have are EL11 and EL3N manufactured by Loewe Opta, a Philips subsidiary located in Berliln. Being a Philips company based in Berlin, Loewe Opta catered to the local German market, the EL11, and the broader European market, the EL3N. The EL11 I have carries the Valvo brand. And the EL3N carries the Philips brand. Again, same tube, different base. And yes, they sound identical.
