I wasn’t very sure what one stage means but this just came through from Glenn. He calls it one tube mode.
All EL3Ns and yes when on one tube mode the audio bypasses the front two drivers and goes straight to
the outputs through the volume control. When in this mode there is no coupling capacitors in the signal path.
The amp is dead silent in this mode just less gain. It still can drive most any headphone but the volume has to
get turned almost all the way up. This also gets the volume control out of the circuit if it is turned all the way up.
Ask Joe about one tube mode he will tell you how it sounds
I love the sound of these tubes.
Matt, two tube mode adds tons of dynamics, staging, resolution....the slam is off the hook.
One tube mode gives you the blackest of black back rounds....as Glenn mentioned, less gain.
When I owned my Grado RS1, I loved it in one tube mode, so clear and transparent...more so than the HD800 in this department.
Just as Glenn says, in one tube mode you can crank the volume control just about all the way up or even all the way if in the mood and the volume pot is out of the circuit
the signal path is nice and clean. Just to get crazy i have used my GS-X mk2 as a pre-amp for one tube mode.....great stuff!
Two tube mode the back round is not as black, but everything gets kicked up 2x to 3x...seriously, it is a wonderful experience.
The amp powers 300 ohm dynamics and planar headphones equally and I can't imagine that there are too many headphones that it will not power.
I know @SoundTrooper uses his Abyss with it and loves it.
As I am sitting here listening to Calvin Russell it with and the LCD-3 ...I am wondering to myself why I want to even try other tubes in this amp to be honest....I guess just because I can
To be perfectly honest I am not expecting anything to sound better than the EL3N tubes...but who knows....Glenn used EL3N tubes as driver and powers for harmonic distortion.
I bought the adapters so I will try different tubes.
Many people have asked what amp that I like best...but that depends on music, headphones ect. I do not need three amps, but I use them all and don't want to part with any.
I will say that I use the GEL3N amp the most, so maybe that is my favorite....if my wife made me keep just one...then I guess i would pick it.
In the larger chassis Glenn can get in everything you would need for it to power speakers, my amp is for headphones only and the chassis is the exact same size as the GOTL chassis.
Here is a pics of all the amps to compare size wise.
Same size as GOTL....not as long as GS-X mk2 but about 4 inches deeper and weighs about 6X more, lol.
I can only imagine how much the larger chassis with the extra guts weighs....but it would be beastly!
Here is the amp using a 4 volt version of the rectifier you just bought...GEC U52
The volume control is between 9 and 10 0'clock in two tube mode here, with the LCD-3....it would be about same position with ZMF Atticus
With the LCD 3 I some times play it way too loud....maybe 12 O'clock....very loud but man the dynamics and impact are killer.
I can not imagine that you would not love the amp...but who knows everyone is different.
Some Calvin Russell for your listening pleasure.
