Didn't look like long exposures to me, how long was the shutter open, LG?
8 seconds I believe at f11. But the room was well-lit, the effect is more pronounced in the dark, I've done 30 second exposures then at high f-stops, oh the tube glow!
So question to @Deyan, is pin 1 left unconnected in the dual 6J5 adapter, or is it taken to ground in the 6SN7 base/socket?
@2359glenn If pin 1 unconnected, can pin 1 be connected to pin 8 at the 6C5 base (with wire)?
Nice, what is hour preferred camera brand (not that matters much...as all brands do well, these days).
Without a ground wire coming out of the adapter to be hooked to the chassis it would have to be hooked up to one of the cathodes.
The cathode resistor bypass capacitor would make a AC path to ground from the shield.
Thanks for your effort in answering. Even if my hi-z headphones such as HD-600 are underpowered on the new GEL3N, I'm still willing to take the risk since it seems my planned Rosson Audio Rad-0 planars and HEDDphone One have a good chance to pair well with it. And I'm willing to take the risk that maybe tube rolling in transformer-coupled amps may not make as large a difference as OTL amps. Unless anyone has another opinion? As long as the amp performs solid that may not matter.I do not own a transformer-coupled amp so I will have to defer to the experience of others. But keep in mind, compared to the GOTL, tube rolling in Glenn's 300B, 45 and EL3N, and also the Woo WA33 for that matter, is almost nonexistent. You can roll different brands of each type, but that is just about it.
And for the new GEL3N amp, I read here recently it's supposed to also work with EL34, EL38 and EL39 considering adapters. And possibly even more if I order custom specs. I'll ask Glenn about the compatible types and number of sockets, but feel free to post that here @2359glenn
So I bought these tubes from Langrex for the new amp and then Glenn told me he can get better sounding tubes for me at $4 each....
OK so no more buying tubes.
