rosgr63
One of the best drivers for the ECBA is the ECC35 even thought the amp uses 6SN7 drivers.
Thanks for the information.Nope. It was an ITT company like STC in UK and Standard Elektrik Lorenz in Germany.
The ECC32 is not on my list... (I do have ECC35 and ECC35)ECC32 installed in a 6SN7 socket is not biased properly. And yet, some claim it sounds better than any properly biased 6SN7.
Hi Zachik,The ECC32 is not on my list... (I do have ECC35 and ECC35)
Should I add it? and does it need an adapter??
Also, what about 6L6GC (or the Russian equivalent 6N3C)? would they work? should I add to my compatibility table?
Updated my list - thanks!!Hi Zachik,
Could not find the 6SL7 tube on your list. It is similar to the 6SN7 but with higher gain. ALL the tubes below are 6SL7 variants:
6SL7/VT-229, 5691, 7F7 (loctal base)
6H9C, 6N9S Russian
6N9P Chinese
ECC35 British
33S29 Swedish
And I am sure there are more variants.....
Hi Zachik,
6H9C, 6N9S Russian
6N9P Chinese
ECC35 British
33S29 Swedish
I'm currently having an amp built by a local builder, and I've opted for 3 different socket types for drivers: C3g (2), 6J5 (2) and a 6SN7 (1). There is also a selector knob on the front of the amp to select which drivers to use, and also the 6SN7 socket can take 12SN7, 6SL7 and 12SL7. All 6 options are selected via the selector knob. These are my chosen selections as I have a lot of these tubes, but I'm sure the selection choice could be endless... perhaps others would prefer a EL32, EL3N, selector, etc.
Hi Zachik,
6H9C, 6N9S Russian
6N9P Chinese
ECC35 British
33S29 Swedish
Hi Keenan,
Yes it is a cocobolo Atticus, and thanks for your kind words. Zach's work is truly impeccable, such a wonderful craftsman.
It is not the hardest or the most dense wood...but it is right up there and it sounds wonderful. The slam of the bass is quite addicting.
Here it is with a fresh coat of polish...I need to polish again soon.
