JazzVinyl
- Jan 7, 2010
The E83F is a good sounding tube to bad the pinout is different from The C3g I would try it if it was the same.
Have no time to play with these nice tubes. I don't even know were I got them from.
Yes, not quite the same...looks like grid3 and grid2 are swapped and grid3 is not tied to cathode as in C3g...
Yes grid 3 is tied to the cathode.
In the pentode valve / vacuum tube, the suppressor grid is generally maintained at a low voltage, often connected directly to the cathode. Its function is to create a lower voltage region between the screen grid and the anode. It suppresses the secondary emission where high energy electrons hitting the anode at high speed have a tendency to bounce off. This effect causes a kink in the response curve of tetrode valves. In this way it enables the pentode to provide a high amplification factor along with the ability to operate at high frequencies.
Looks like Mrs Xuling is following the Glenn thread:
https://www.ebay.com/itm/1Piece-EL3...=item2f260a7797:g:QZIAAOSw5wVb63hW:rk:20:pf:0
https://www.ebay.com/itm/1Piece-6SJ...=item2f260a78f2:g:3~MAAOSwfX9b63i7:rk:21:pf:0
I am going to try the $5 EL32 tubes and the no frills adapters......
Also looking for an inexpensive source for the GE 5star 5670 with the triple mica.
The EL11s should sound better in the C3g socket as long as she wired them straight through as a pentode.
And they are not triode wired like in a FA amp. Looking at the circuit board I see trace jumping a couple of pins maybe I am seeing something that isn't there.
6SJ7 another good sounding tube for cheep.
Which type is the best one? Metal tube tube? Russian metal tube? Glass tube? Glass with mesh plate?6sj7 is the driver used in La Figaro 339.
RCA 5693
Ken-Rad 6SJ7
Glass Sylvania 6SJ7GT - VT116
Triangle 6SJ7 with mesh plate
Lots of choices at very low prices.
