UntilThen
- Jun 16, 2015
Really cheep $10.50 why shch a low price?
No frills.
Telefunken
Hey JV,
The c3gs with a six pack of GE 6BX7s really pack a punch on the HD650s. I can't imagine taking much more force! Which VT-231s are you using JV?
The adapters are $25 each, including shipping. Each one is made to order. If you have any special requests he will accommodate you.That's a much better option Mordy. How much are they?
Hello PH...
Ken-Rad for VT-231
Using 6BL not 6BX, BL's even more gain than BX, have to turn the input down a bit not to have too much gain.
But that said...one of my absolute favorite combo's in the GOTL is:
Six pack 6BL7
and
ECC88 Amperex (Phillips) as driver
Just right, for my tastes/phones.
Thanks. I don't have any Telefunkens, but I do have some that seem to have a similar construction.
Since they all seem to sound the same or very similar, I like the RCA, just because i am addicted to their glow.
I need to find a couple more sets for the upcoming OTL.
Love that these tubes are so cheap.
Yesterday I got into a roll frenzie and listened to all three of the Amperex 6922s I had. One is from Holland, the other two from the US but one is a pinched waist. While I really enjoyed he smoothness of the Holland (very liquid) it had a rolled off bottom end. I more enjoyed the US Amperex. Good taste in tubes JV.
Is the Ken-Rad VT231 the same as a Sylvania Badboy? I like that tube as well.
According to Glenn the bias setting for the C3g should be closer to the bias of EL tubes than the bias for the 6SN7.$25 for a custom made adapter is reasonable. To fit the c3g base is not easy. I'll try out the adapters from Mrs Xu first to see if the EL11s sound any different from what they are as dual in the 6sn7 slot.
I had the EL11s and 6bx7s in the OTL amp for 2 weeks already.
I will send you a bunch of them really don't use them anymore and I have like 20 of them.
Going through junk looking for something else I found two of these tubes 95397. They look like a 9 pin tube in a Loctal adapter but they are not.
They are Loctal tubes Philips SQ tube special quality. Have no idea what the pin configuration is can't find anything.
