rnros
- Sep 12, 2004
If I hadn't listen to these tubes before I wouldn't dare plunge in but I have quite extensively. In an amp not design to run it but it sounded good. I've never tried EL12 spez but I've tried EL11, EL12, EL12n both as driver and power tubes. They sound dynamic, clear, bold and energetic. It's like EL3N with the heavens open.
Now I'll have to try those. At least the EL11s. Project sounds exciting. And more every day.
Good idea to keep the tube rectifier. Definitely helps to shape the SQ. May be all you will ever want or need with those tubes.
Some good and inexpensive rectifiers available for experimentation. Previously recommended by Glenn on this thread.
Even if they never become a favorite, the experimentation is interesting. Less than $20.
Case in point, 5AW4 cleans up the little bit of extra bass diffusion I hear with the 6BL7s, makes them as good as the 6BX7s to my ear.
Another is the 5CU4, but that may not have the PIV you need. I think the 5AW4 is OK.
RK60 has rich low end, not excessive, only $40, may be nice with the Telefunken.
