2359glenn | studio
May 26, 2018 at 10:31 PM Post #20,521 of 39,983
Just one more Joe. Just one more rectifier..... :)
After the rather intense bidding of the Osram U52 which I did when I was having dinner at a restaurant, I just need another gz37. Whether it's the fat bottle or the skinny Mullard remains to be seen. :)
May 26, 2018 at 10:43 PM Post #20,522 of 39,983
I have 7 octal gold plated socket savers from mrsxuling for sale. It's been used only once. I'll take 10% off mrsxuling price. Don't need these now. My tube rolling on the OTL is over. I'm set on 6 x 6bx7gt as power tubes and they will remain there. Only the driver gets rolled now and even that isn't happening a lot now. I'm just enjoying music.
So if you need 7 golden socket savers, PM me. :)
May 26, 2018 at 10:54 PM Post #20,523 of 39,983
Hi UT,
In addition to the ST type EL11 and straight glass TFKs, there is one more variant - a Loewe-Opta small size ST type tube.
IMHO the best sounding ones are the Telefunken ST type.
May 26, 2018 at 10:57 PM Post #20,524 of 39,983
Mordy are they on sale? Provide link please. I have a specialised EL11 / EL12 spez amp so I have to ensure I have enough tubes to last 3 lifetime.
May 26, 2018 at 11:08 PM Post #20,525 of 39,983
Hi UT,
The small Loewe-Opta are quite rare and I only have one. A quick search on eBay yielded a single offer:
https://www.ebay.com/itm/GEPRUFT-Ro...341415?hash=item5458479e27:g:XCoAAOSw--Fa-HEQ
It says that this tube has been in their warehouse since 2009 - could not be too much demand..
I have had good luck with Google translate in understanding offerings and in communicating with sellers.
GEPRÜFT: Röhre EL11 Loewe Opta
Wir verbürgen uns für die einwandfreie Funktion dieser mindestens "gut" geprüften Röhre mit der EAN-Nr. 4051154066424
sind Sie nicht vollends zufrieden, tauschen wir sie umgehend um oder erstatten Ihnen den Kaufpreis,
diese Röhre Nr. 7459 wurde mit einem Röhrenprüfgerät Funke W19 geprüft,
ggf. können aufgedruckte Beschriftungen teilweise unleserlich geworden sein.
Angebotsnummer 7459,
Ausführung und Lieferumfang wie abgebildet und beschrieben,
der Artikel ist voll funktionsfähig, sofern nicht in diesem Angebot 7459 ausdrücklich anders beschrieben,
wir haben den Artikel 7459 im Januar 2009 in unseren Lagerbestand aufgenommen.
VERIFIED: Tube EL11 Loewe Opta We vouch for the perfect function of this at least "well" tested tube with the EAN no. 4051154066424 If you are not completely satisfied, we will replace it immediately or refund you the purchase price, this tube No. 7459 was tested with a tube tester spark W19, possibly printed labels may have become partially illegible. Offer number 7459, Design and scope of delivery as shown and described, the article is fully functional, unless explicitly stated otherwise in this offer 7459, We have added item 7459 to our stock in January 2009.
As always, there are anomalies in the translation; as an example "Verified" should be translated "Tested." The Tube tester brand name is Funke which means "spark."
Tested "well" should be translated "good." etc etc
BTW, for you to complete your collection of EL12 Spez, I found a picture of a TFK "Plattfuss'" one:
Could be a mistake though - maybe EL6?
Plattfuss=flat foot=side contact
May 27, 2018 at 7:30 AM Post #20,528 of 39,983
What driver are you using?
May 27, 2018 at 7:45 AM Post #20,530 of 39,983
Nice sounding tube.
This EL11 - EL12spez amp I am building for you will be the first amp that I sold that didn't listen to the tubes/amp first.
Except amps for Stavros but that is different I gave him most of my experiments. Your OTL with all the output tube sockets
Stavros was my Ginny Pig.
I do expect the EL11 - EL12spez amp to sound great!!
May 27, 2018 at 7:55 AM Post #20,531 of 39,983
Didn't you do the same for the 45 amp for Tyrell?
It's ok. I'll let you keep the EL12 spez amp for a month to listen. Make sure you get to enjoy the fruit of your labour. :)
I think it will be great. These are great tubes; Look at this vintage Telefunken tube amp using EL12 spez.
One RARE vintage Telefunken ELA V300 tube amplifier. Made in Germany in the 1950s. Made for PROFESSIONAL use. Output power is 25 Watt from 2x EL12 spez. PP and 3x ECC81. With high quality microphone transformer. For all common main voltages between 110V and 240V. See pictures.
https://www.ebay.com.sg/itm/TELEFUNKEN-vintage-TUBE-amplifier-ELA-V300-EL12-spez-PP-/311181038268
May 27, 2018 at 8:11 AM Post #20,532 of 39,983
If I hadn't listen to these tubes before I wouldn't dare plunge in but I have quite extensively. In an amp not design to run it but it sounded good. I've never tried EL12 spez but I've tried EL11, EL12, EL12n both as driver and power tubes. They sound dynamic, clear, bold and energetic. It's like EL3N with the heavens open.
What you do will be totally different though. Transformer coupled with quality Lundahl transformers that you use in your 300b amps. It will be special. I look forward to my 1st transformer coupled amp.
May 27, 2018 at 9:00 AM Post #20,535 of 39,983
Coming off EL11 is good because it's a good sounding tube.
Probably a switch to either preamp or power amp. Guess I can't listen to both headphones and speakers at the same time.
