2359glenn
Member of the Trade
- Aug 16, 2010
The GZ34 is a great tube but not a looker plain little tube
For those interested in the Raytheon CK 5694 double triode, there are a pair on eBay:
https://www.ebay.com/itm/173330819442
Current bid is 51 US dollars for the pair.
Are you kidding me?
Stolen from the net....
The Raytheon CK-5694. Electronically similar to a British made ECC32 / CV-181. I am using them as 6SN7 GTB substitutes to drive a pair of 845s. They were ignored because they have a non-standard octal pin-out, which means that they require a small adapter. Professionally made adapters to convert them to a 6SN7 pin-out, are currently available on Ebay for $15.90 each. They feature lower noise, more dynamics, and are better across the entire frequency spectrum. Easily outperform the Mullard & Chelmer Valve ECC32 / CV-181, which go for $600 to $650 a pair at "Tube World", when available.. These tubes are be careful what you ask for, They will reproduce every thing that comes from your source, the good, the bad, and the ugly. Analog, in every sense of the word. If you like digital effects, these are not for you. I am listening to them through custom four-ways, using only first order cross-overs, they allow no room for error. The Raytheon CK-5694, easily the best NOS tube that I have ever owned. One matched & balanced pair available at $400. THESE ARE NOT DIRECT 6SN7 SUBSTITUTES, PLEASE CONSULT AN AUDIO TECHNICIAN BEFORE USING IN YOUR EQUIPMENT! I have a customer who is using them in place of a 6DJ8 / ECC88, in a DAC, with a vacuum tube based output stage, with great results!
Are you kidding me?
