whirlwind
While waiting in the queue for a Glenn amp I decided to shop for the 5A Cetron 6336B graphite tubes that some people seem to like a lot.
My present FA Elise amp can only accept 6.8A of firepower.
Did I say firepower? These could double as heaters on a cold winter night lol....
However, the tubes have arrived and I have to test them. Now.
What to do?
Dug up my Glenn inspired 6 octal tube adapter, a 15A/12V computer power supply and a 15A voltage regulator from my early Elise days.
Connected everything, and it works! And even though the PS and voltage regulator are cheap stuff, there is no noise or hum even at full volume.
The amp is downright cold with only a load of 1.2A, but the heat sinks on the voltage regulator gets hot. After the big tubes warmed up I only needed 10 o'clock volume (my usual) for good volume. Although I did not try to match the Cetrons with synergistic drivers yet (now using side getter Foton 6H8C from the 60's), the great and detailed bass is readily evident.
Just imagine being able to use these American Muscle tubes without all the makeshift stuff in a proper Glenn amp!
Nice tubes
![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
Nice to use socket savers with these tubes, takes away some of the heat from the chassis
These will keep you warm on a cold winters night.
