SonicTrance
Member of the Trade: Custom Amp Builder
Thanks! It also sounds goodNice amp you have there
Latest build with XLR input and preamp output.
Thought I was running out of room using Amphenol XLR jacks.
Beautiful! I got very excited and thought that was mine at first, but I was expecting a preamp tube socket? Actually I think (hope) that is mine. It looks absolutely incredible.
It is yours no preamp tube socket ran out of room uses the existing tubs just have to find quiet ones.
And they are good sounding tubes in there.
Very nice, definitely a chassis full.
You will soon have to go to the bigger chassis for your OTL amps
Brilliant, really looking forward to this beauty! So, the preamp power tubes are just using the existing power tubes. Noise aside, are there any do's and dont's, e.g. 6 x 6BL7 or 6BX7 will still be ok?
Grabbed this sweet looking solid state rectifier with a decorative tube-shaped top for like $15 the other day on eBay. Listening right now with the Acoustic Research AR-H1, a pair of 6336 power tubes and a Sylvania 6SN7, and it sounds awesome. Tight and punchy sound. I like the speed, but I do like the sound of my tube rectifiers too. Anyway, good option to have when the mood strikes, since one can easily get a plug-in solid state rectifier for $10-$15.
It certainly looks cool... But I wonder, is it advertised as a HEXFRED?
While waiting in the queue for a Glenn amp I decided to shop for the 5A Cetron 6336B graphite tubes that some people seem to like a lot.
My present FA Elise amp can only accept 6.8A of firepower.
Did I say firepower? These could double as heaters on a cold winter night lol....
However, the tubes have arrived and I have to test them. Now.
What to do?
Dug up my Glenn inspired 6 octal tube adapter, a 15A/12V computer power supply and a 15A voltage regulator from my early Elise days.
Connected everything, and it works! And even though the PS and voltage regulator are cheap stuff, there is no noise or hum even at full volume.
The amp is downright cold with only a load of 1.2A, but the heat sinks on the voltage regulator gets hot. After the big tubes warmed up I only needed 10 o'clock volume (my usual) for good volume. Although I did not try to match the Cetrons with synergistic drivers yet (now using side getter Foton 6H8C from the 60's), the great and detailed bass is readily evident.
Just imagine being able to use these American Muscle tubes without all the makeshift stuff in a proper Glenn amp!
