- Aug 2, 2014
Don't tempt me. I will leave the rest of the 6BX7 brands for @UntilThen to test.
While I have some 25 6BL7, I only have 6 6BX7. Rebranding was very common, and I have BX GE tubes that say RCA and Westinghouse, so looking for these GE tubes might be even less money than GE branded.While Tung-Sol and Fivre are a bit rare and hard to find, GE are plentiful, cheap and sound very good, so I encourage you to grab six of them.
I guess it was in the Littledot thread because i and a few other guys had cracked a tube. you just cant wiggle that tube when removing it you just pull straight out. I just left them in the adapters .Eventually i found these loctal sockets way better .
Hahahahaha...with the sheer amount of tube combinations to be had, it kinda freaks me out..i shall continue lurking first and reading more impressions of yours once you've had more time acclimatising to the amp before deciding my next move
Hi UT,Mordy !!! What are you waiting for. Glenn Super 9 OTL amp is perfect for those tubes. I haven't touch my speaker system for 3 days !!!
Hi UT,
I am thinking about it, but I need to know more about the amp and the various options and their price/performance ratios to be able to make an informed decision. I am awaiting clarification on some items from Glenn.
Another question: What is the purpose of the single socket in the front of the amp? Is it meant to use for a dual triode in two channel mode?
I remember that when the Elise was in the planning stages, Feliks decided to use two 6SN7 type tubes as drivers, even though one would suffice. Something about improved sound with two tubes working in parallel(?).
When are you going to test out the 3A Russian 6C33C horned beasts?
It depends on the driver and rectifier. Since the Sylvanias are pretty lively and sparkly, rolling in a darker rectifier and driver, such as the Cossor 53KU and a pair of RCA 76 triodes sounds great to my ears. And since the GE are a bit more neutral, rolling in a GEC U18/20 with a Sylvania 6SN7W sounds great. Again, it is all about synergy and matching.
I hear you, Matt.Omg Ken, prices for 6BX7 / 6BL7 tubes are going to skyrocket now. Please keep it low key. Do what attmci did. Insist that the WE421A tubes are better.
I thought the GEC tubes were very good but I needed to hear C3G - 6BX7 again. So in they go again. While I agree with you Joe and Arnold that the beauty of this amp is the many tones we can custom it with but this C3G - 6BX7 is it. Wow just wow. With HD800, this is high fidelity. This has shot to top of the class. You need to listen to C3Gs with 6 x 6BX7. This is where the magic is.
A caution though. When I had seated all the tubes, I detected a constant hum on the right channel that wasn't there the first time I heard this combination. I could tell it's from the right C3G. I tap it lightly with my finger and hey presto, the hum disappeared. So make sure you seat it correctly and leave it alone.
