Ross do it and no scaling back. Your only choice would be whether it's tube or hexfred rectifier. Frankly I am very happy with hexfred even though I haven't heard tube rectifiers. I have just started tube rolling so I cannot give you a firm answer on my fav tube combo but for a muscular, dynamic, hard hitting sound, it's hard to go past C3Gs with 6 x 6BX7 or C3Gs with quad 5998.
I don't know what it's like not having Gold Point attenuator but that will save you $300. The boost switch has a marginal gain increase but in this amp a marginal increase is significant.
There's really nothing to scale back. I would still go with the same configuration if I have to do it again. I'm now running Brimar 13D1 (25 volt) with 2 x Mullard 6080 and 2 x Bendix 6080wb. I'm liking these quad power tubes. It has that extra ooomph.
Ross, I prefer this setup of Yggdrasil > GOTL > HD800 over Yggdrasil > Blue Hawaii > Stax SR-009. It's as resolving from recollection and more dynamic and impactful certainly. Much cheaper definitely. Glenn's amps are incredible value.
