mordy
- Aug 8, 2010
About the fragility of the C3g tubes:I broke one of my c3g because the adapter was too tight
I make the adapter loose by opening up the adapter using small screw driver
It is my belief that the tempered glass envelope is more fragile than other tubes (perhaps because these tubes were used for under water transatlantic cables and they required a different kind of glass envelope to withstand high pressures).
Most tubes are removed by a rocking action ("rolling tubes"). This could result in glass breakage with C3g tubes. The best way is to push them straight in, and use a small thin flat screwdriver to gradually pry around the bottom of the tube and slowly lift it up little by little.
Enlarging and loosening up the pin holes, especially the center pin, also helps.
BTW, this learning experience cost me two C3gS tubes.....
