average_joe
- Dec 5, 2008
Firstly, thanks for the great review average_joe
I may have missed it in all these posts, but I cant remember seeing a comparison of the microphonics of the cables vs the stock JH16 cable?
I have a JH13 and JH16 on order and I am guessing that they both use the same cable. I am finding the JH13 cable to be very microphonic, especially when I have been spoilt with ACS's T1 kevlar cable.
When I move around, I am very aware of the rubbing sound of the cable on my shirt collars or sides of my face (maybe my head is too big...lol).
Can you recommend a replacement that is much less microphonic than the stock JH cable?
Joe, is the uerm cable compatible with the tf10?
Hi average_joe,
following your comment about not having any issues with your cable, I've done a bit more testing and its a little wierd.
The cables are securely wrapped around the back of my ears.
I can hear the rubbing against my cheeks and when the Y cables touch my shirt collars. Tightening the cable slider helps as it stops the cable moving around quite so much. The strange thing is that if I hold the cable between two fingers and run my fingers down the cable I get the microphonic rubbing for about 12 inches after the Y section andf then it abruptly stops and is dead quiet!
I am now wondering if there is a problem with the cable as the microphonics dont just fade out but go instantly quiet after a certain point down the cable.
I assume this doesnt happen with yours?
I''ll let you know if this also happens with my JH16 when they arrive.
Cheers
How long do you burn in your cable joe?
300 hours. The TWag cable needed that as do some others, it seems, so I use the same number for all to be fair.
