You should feel lucky that you caught that! How was it?
☯️ Cavalli Audio's Liquid Carbon... a $599 Cavalli amp???
- Thread starter warrenpchi
DigitalFreak
镇老鹰
- Jan 1, 2011
pretty darn good. I wish I had more time with the Paradox in balanced. I'm not completely sure but i think the midrange sounded slightly more forward then what I'm used to. Sometimes when the midrange sounds cleaner I mistake it for sounding forward.
aamefford
I have a custom title!
- Nov 28, 2007
During my search for a nice, right sized DAC to use with the liquid carbon, I have run across the Emotiva DC-1. I point it out, as it's specs state "Pro level output at the balanced output". This pro level output is +6 dbV. Is this excessive for the liquid carbon? In other words, is the gain going to end up being way too high with this level? I want to avoid running too high of a signal into the amp, and not having enough volume travel to adequately adjust volume on sensitive headphones, or conversely, too low of a signal, and having to crank the volume to near max to get to listenable levels. Comments appreciated!
Did the Carbon in the shows recently have a muting relay for those who heard it? still interested to know if there is one, or one planned for it in the future.
MattTCG
- Jan 22, 2012
If the output level is +6 fixed, then I'd say it's too much.
aamefford
- Nov 28, 2007
I found the following calculator: http://www.sengpielaudio.com/calculator-db-volt.htm
Doing my best trained monkey imitation (no offense to any trained monkeys in the audience) I see that +6 dbV is essentially 2 vrms. This is kinda sorta the input voltage standard, isn't it?
Dr. Cavalli - care to weigh in on what would be "reasonable" input levels for the balanced and single ended inputs?
MattTCG
- Jan 22, 2012
Occasionally I'd like to have use of my momentum 2 at the desktop for isolation when the house is noisy-busy. Is there any reason why the Carbon would not pair well with this headphone?
nudd
- May 2, 2013
Studio level line out references +4 dbU, so I think that is 1.2 v. +6 dbV would be quite a bit higher than that, so I suspect that it is a bit higher than what would be expected.
- Oct 26, 2008
Emotiva now has a rep on board here. Let's see if this works.....
@KeithEmo ?
stjj89
- Jul 4, 2013
Does anyone have an opinion on whether the Liquid Carbon would be a good match for the TH900 (running single-ended)?
DigitalFreak
镇老鹰
- Jan 1, 2011
How about us monkeys who are still in training? We're not just a bunch second bananas bud.
jjacq
Playing Upgraditis Mania
- Feb 24, 2012
To those who have heard the carbon, do you guys think it'd be something that can contend with the Schiit Mjolnir?
aarontyson
- Feb 12, 2015
Having never heard the Schiit Mjolnir, I would think they are very different amps. For one the Mjolnir has more power and probably has a completely different Topolgy. I would think the Cavalli would sound similar or better IMO. Hopefully someone who knows will reply.
dusk
- Mar 16, 2005
screw it, just bought one
