aqsw
- Jun 17, 2010
h34r:
your like a crack dealer. Lol
h34r:
I know there's a lot of talk about transportable balanced DAC's for the LC, but if you're not concerned about any of that and just want a really good DAC for the money ... you should definitely have an eye on the Audio-GD DAC-19. It's SE and it's too big to lug anywhere, but it's R2R (some of the last new TI R2R chips in the wild!) and it sounds really good. I intend to post more impressions of the DAC-19 as I let my ears settle in, but so far so good.
but how about a good, balanced dac.?:rolleyes:It's more important to be a good DAC, then a balanced DAC....
The balanced version of the DAC-19 is the Reference-10.32. I costs literally double the price and I highly suspect that it doesn't give double the SQ. And at that point you're very close to Yggy dollars...
I did a comparison of the Gungnir SE vs. balanced output into the Ragnarok with my LCD-X's. The comparison was easy because the Gungnir simultaneously outputs both signals and the Rag has switchable multiple inputs. It sounds like there's a small difference, but depending on the recording, it can be tough to discern any difference. While I'm pretty certain there's small difference, I'm not sure I could reliably pick it out in a blind test. Any time I find myself straining to detect a difference, it's not something I'm going to worry about.
It would be great to find a well-designed compact DAC to complement the LC. My goal is having an easily transportable setup to use in different parts of my house.
Have you looked at the Chord 2Cute? Looks transportable, and the reviews have been fantastic so far, though depending on your budget it may be a bit expensive.
I really don't understand the love of chord on head fi.
Two words: Over Priced
For Christs sake, you can get a Lampizator Amber for close to the same price as a Hugo. What's wrong here?
