Please forgive the massive first post...
I.e. the new board does 4:4:4 (full chroma, necessary for PC's over HDMI) at 4k/60hz?
It will support 4:4:4 but only 8bit. This is a limitation of HDMI 2.0 spec (it does not have sufficient bandwidth and 2.0b doesn't fix this). Anyone wanting to use Realiser A16 will need to use DisplayPort if they want 4K 60hz 4:4:4 10bit --- or 4K HDR at >60hz (FreeSync 2 monitors are arriving very soon!). This will change in 2018 when HDMI 2.1 becomes available, but until then DisplayPort is the only option - and not a very good one....
It's notoriously difficult to get a GPU to just send audio down an unused HDMI output - it must be
enabled as a display in Windows and you can't do this without a connected display under Windows 10. Once again: HDCP serves only to frustrate. You could try to mirror your Displayport output to HDMI -> Realiser. Depending on your GPU/driver/luck, you will almost certainly get one or more of:
- Drop in performance
- Displayport will drop back to 60hz
- You will constantly have to switch your audio output device on PC
- It won't work
https://forums.geforce.com/default/...s/feature-request-hdmi-audio-without-display/
For anyone affected by this and planning to run the Realiser "headless":
PC --> DisplayPort --> Monitor
PC --> HDMI --> Realiser A16 HDMI Input 1
Realiser HDMI Out -->
nothing
It's likely that the GPU will detect no Display EDID and refuse to output audio to HDMI. You will need something like this on the Realiser HDMI Output :
https://www.amazon.com/CompuLab-4K-Display-Emulator-fit-Headless/dp/B00JKFTYA8
(Only supports 15hz @ 4K - This
might cause refresh rate issues with your primary DisplayPort output...)
If you want want to use HDMI for other devices as well, like:
BluRay --> HDMI --> Realiser A16 HDMI Input 2
Realiser HDMI Out --> TV/Projector
Then you'll encounter other issues:
1) Your PC won't send audio to the Realiser A16 while your TV is off
2) You will be constantly having to switch audio output device on your PC
So... You might need to put something like this between your PC and the Realiser:
https://www.amazon.com/Orei-Splitter-Ports-Supports-Control/dp/B06WRV8V1F
This
should allow you to pass audio to the Realiser over HDMI with a spoofed EDID for the GPU.
All this becomes simpler in 2018 with HDMI 2.1 of course... I'm actually hopeful that we might get a software update for Realiser to support at least part of the HDMI 2.1 spec without needing a board upgrade. Backtracking through Realiser A16 posts/updates:
August 2016:
"We use an HDMI repeater board from MDS in California and they tell us every customer is asking for the same thing. The issue at the moment is the lack of HDMI chips that support 2.1 - in other words it will take time for the IC manufacturers to catch up. However MDS are presently working on a 2.0a board that is a drop-in replacement for the board we use and they see a 2.1 board in the pipeline immediately following that. So in time the A16 will be able to support what you ask. The HDMI board inside the A16 can be easily disconnected from the motherboard, so it should be possible for owners to retrofit themselves, or have it done at the distributor."
April 2017: Realiser upgrades MDS board to support HDMI
2.0a (4K HDR on a single HDMI input)
https://www.kickstarter.com/project...al-3d-audio-headphone-processor/posts/1858178
June 2017: Realiser is now waiting on a new board with HDMI 2.0b
"We can confirm that the A16 will ship with HDMI 2.0b HDCP2.2 functionality on all HDMI inputs and output. The 2.0b provides support for Ultra HD @4kx2k 50/60Hz as well as all three HDR variants HDR10, HLG and Dolby Vision. We are still in the process of establishing an exact shipping date for this new HDMI board from MDS but we hope to take delivery around late August to early September."
While I imagine neither MDS nor Smyth can promise anything - it might be possible that this board might be capable of 2.1 down the track and could receive a firmware update once the spec is finalised?
Probably wishful thinking!
