Denis Iastrebov
- Mar 14, 2014
Will Fiio K5 be enough to drive the DT990 600 Ohm?
PART 3 - AMPING THE HEADPHONES
UPDATED ON 12/17/2011
This section will be just about amping the headphones properly. I will give specifics on what you should use to power them and what not to use.
___________________________________________________________________________
[size=18pt]32Ohm Models[/size]
Despite their low Ohm rating, the 32Ohm variants actually will need a little more power than what the 250Ohm require. The reason they need a bit more juice is because of their sensitivity and impedance. They have both a really low impedance and a lower sensitivity rating, thus they will need more power. Take the K701/K702 for example: despite it's low impedance (62Ohms I beleive), they have a very low sensitivity. The more sensitive a headphone is the easier they will be to power and reach a desired volume. The DT770/32 have a impedance of 32Ohms and a sensitivity rating of 101dB. This makes than a bit more difficult tog et to the desired volume and power properly. I believe they require a nice voltage swing as well as more current than most 32Ohm headphones.
[size=18pt]250Ohm Models[/size]
Now despite these having a higher Ohm rating than the previous model, it is in fact a bit easier to amp. This time the impedance works in it's favor and widen the gap between the impedance and sensitivity. I am not sure of the exact specifics but I know now that the higher impedance coupled with the sensitivity now makes these crave more voltage than current.
For these you could use a nice solid state amp but it would have to have a higher voltage swing than normal. Really anything that can swing about 20V P-2-P should drive them jsut fine, but an even higher voltage swing do do them more justice. For the higher voltage swing I could recommend a nice OTL tube amp. You could use the: Woo Audio 3, CSP2+, Darkvoice 336, and the Bottlehead Crack amps. There are probably many more out there that would do ust fine, but these are ones I ahve either heard or own.
I also found that my X-CANV8P could drive the 250Ohm models very nicely. Not quite up to par with a fully fledged OTL amp but darned good.
DT880 32 ohm vs 250 ohm
Your post has confused me quite a bit. I plan on using the headphones primarily through a laptop headphone output so thought the 32ohm was the one to go for. I have tried the 32ohm and my laptop gave them plenty of juice allowing them to get louder than needed.There's quite a noise floor in this scenario. I did find my android phone (LG G4) struggled to get them up to the desired volume level however. Beyers site recommends the 32ohm for portable devices and I assume this includes laptops although it's a bit of a grey area. Most people seem to say the 250 and 600 sound better than the 32 ohm yet some reviews I read here say that the 32 has more in common with the 600 ohm (which seem to be considered the best model available if you can drive them). Please could you offer advice on whether I should get the 32ohm or 250ohm for mostly laptop use (and sometimes external soundcard use)
Thanks,
Pete
Thanks,
Pete
Thanks,
Pete
Amazing guide. Thanks!
Will a Asus Xonar DX sound card be enough to drive the DT770 250 Ohm?
Thanks in advance!
