Wildcatsare1
Personally, I prefer the Universal Lambskin, though the Suede is pretty close.
My Verite should be shipping out later this week. What pad and material would you recommend if I wanted a more warm, lush mid, and not so bright sound signature?
The pads that ship attached,Universe pads.
They are perforated, no?
So I’ve decided I’m going to get a Verite but in the meantime while I’m in the queue I’d like to upgrade my frontend. I’m thinking of either getting a GSX Mini or Zachs own Pendant amp as the tubes arent too expensive and its a fast amp. Does anyone have any experience with it?
Additionally, does anyone have any recommendations for tube amps around $2K that don’t sound soft? I want something that slams like a SS and also preserves some air, has detail, etc. I feel like a lot of tube amps around that price sound too bloomy or too soft sounding which takes away from the great speed of the Verite.
I’ve only heard both the amps you mention at Meets, so grain of salt, but if the Vérité is going to be your main headphone I’d go with the Pendent. It’s a powerful tube amp, and you can change the flavor with different tubes!
Hey! I have a pendant at home, that I used a lot with the auteur (and soon I will have the verite!). I can telly you it's an incredibly fast and resolving amp, with the most "liquid" sound I ever heard...dynamics are amazing, and the overall tone is pretty neutral-I would say a little bit v shaped for being a tube amp? Bass is very powerful and treble is not laid back at all. It's a wonderful pairing with the zmf cans mids!
The cost of the tubes is a huge plus, I have a 300b amp (that I love) so tube pain is a very familiar feeling! I liked the Pendent’s versatility, it plays well with both high ohm dynamics or low z planers.
Thanks for your insight! Glad to see youre enjoying yours and that its a fast amp. Any really good tubes you recommend? Is it worth swapping input and rectifier or all tubes? Do some affect the sound more than others? From other tube amps I’ve owned in the past the rectifier usually was the one that changed the sound the most while you could fine tune with the input tubes.
ZMF headphones hand-crafts wood headphones in Chicago, USA with special attention to exceptional sound and craftsmanship.
Stay updated on ZMFheadphones at their sponsor profile on Head-Fi.
How is the 3 dimensionality with the Telefunken in place? On the GOTL Ive noticed that the brighter the tubes,the less depth I get.Also - as far as tubes, I've found I like the 12au7's the best with ZMF's for more play on the volume knob as the gain is lower. I've been using a NOS Bugle boy and Telefunken diamond 12au7
