- Aug 2, 2014
Impressions to come after I've had some time, but 3 songs in I am in love. This thing is made for metal
That what I keep trying to tell people!
\m/ \m/
It's interesting how you can really see the pores on that teak, as opposed to the EMU Teak headphones whose cups appear to be very smooth/semi-glossy.
https://www.massdrop.com/buy/e-mu-teak-headphones
\m/ \m/
Man you really nailed the review on this thing. I am grooving along to bass lines which I've never heard with such clarity and visceral impact before, they are not overpowering or overbearing, just RIGHT
How would you compare the bass to the Atticus, especially in terms of visceral impact?Thanks man! Yeah, I love the bass on the Auteur, it’s so good!
It depends a lot on the amp, but generally the Atticus hits bigger and rounder in the midbass with a sizable hump in that region, has a warm lower midrange, and subbass that is a bit less clear and rolls off earlier.
Auteur is flatter through the subbass, midbass and lower mid - more like a planar, but the driver also hits with a lot of visceral force, even with less total volume than Atticus. The Auteur is more clear and defined, especially as you start to go below 70 or 80Hz. The Auteur is faster in both attack and decay while the Atticus is more rounded. Auteur will give you a more connected sense of PRAT. More presence in the subbass means the Auteur may hit harder in some scenarios, depending on the fundamental frequency.
If I’m comparing it to other things... let’s see. In a football analogy, the Auteur is like a linebacker and the Atticus is like a big defensive lineman. Auteur is faster and can do more things. It is violent and explosive. Atticus relies on its power and strength - everything it does is big and massive.
If they were tools, Auteur would be a claw hammer and Atticus would be a mallet. You can swing the hammer faster, whereas the mallet swings a little slower, but with more weight behind it. They might release similar amounts of energy, but one relies more on its mass to do the work while the other relies on its lesser mass but higher velocity to create the energy at the point of impact.
Reminds me of this: "If the Auteur were a president, she would be Baberaham Lincoln."It depends a lot on the amp, but generally the Atticus hits bigger and rounder in the midbass with a sizable hump in that region, has a warm lower midrange, and subbass that is a bit less clear and rolls off earlier.
