All hello again. Can u recommend me some good cable for Zishan t1 balance out? It must be marked as TRRS and 2.5 mm, right? For example here https://ru.aliexpress.com/item/3302...&terminal_id=857888ded698499ca6b0c1dd29062c14 (i need mmcx)
Hi, on budget I recommend yinyoo 6 core cable. Only exists in copper color. No earhooks but it's so supple that it works fine over-ear if needed. Works with my DSD so works with T1. Personally I find trn t2 sub-par, it's heavy and tangles and the braiding isn't great. 16 cores being the sale point.. but is "more" really better? Not in my book.
My favourite is NICEHCK 16 Core High Purity Copper Cable 3.5/2.5/4.4mm Plug MMCX/2Pin Connector Cable For TRN V80 AS10 BA10 NICEHCK M6 HK8 NK10 Got 2, will probably get another one on 11.11 No earhooks help with precise fit, sound-wise reduces harshness just a bit with BA IEMs Very soft and flexible, yet reasonably light-weight for 16 core.
They look similar, but I don’t have the cable you linked, so cannot comment on that one. But I can recommend a really good one that I have and like a lot, the NiceHCK one - copy paste description in Ali and it will pop up (cannot post a working link from mobile, sorry) Hope it helps.
I already have one TRN, 16-cores, copper color, but with 3.5 minijack. Very good cable. Difference between NiceHCK is just Name)) I mean which one need for balance out - TRRS? 2.5 mm?
Hello, Well, I was also in the same problem as yours. The 2.5mm BL port has got my attention so much, so I decided to buy the silver TRN-T2 a week ago. Does it worth the money? I'd say yes. Why? 1. The product quality is pretty beautiful (silver color). It's just suit my taste (might be different with yours) 2. Thick, and the price is also reasonable. I bought it for $10. So pretty good in my opinion. Also, I'm pretty satisfied with the Y splitter and adjuster, suited my needs. 3. There's a lot of configuration on the cable, both on connector and plug (in my case, I bought the 2.5mm with 0.78 pin connector). Now, I can use the both balance and single-ended cans, which is pretty fun for experiments Sound quality wise, doesn't improve a lot. Maybe 5% improved, but mostly at separation and soundstage section. On the tri-band equalization, doesn't really improved, IMO. Would I recommend this cable? Straight yes. Yes if you're not looking for sound improvements, just pure 2.5mm 16 core cable with great product quality for the price. Hi citral, I respect your opinion in the TRN T2. Personally I like the T2. Thick, heavy and "16 core". About the braiding quality, yes it's not the best. But for me, definitely deserve my appreciation, since this is hand-braided (and it's good). But again, different people = different opinion and perspective.
Sure, no problem, I got the "silver" like paint in balanced too and don't like the color, just personal taste
Kudos, @Dblackdock9 for this info (see below) I believe these shoulderless adapters will also fit into the T1’s lpf as a single to dual adapters for some users’ favorite single packaging op amps to fitting them in the T1 enclosure! I’ll eventually source the parts and save some money doing this on my own but right now it’s convenient to order these Browndog adapters! Wasn’t sure if there was a way to fit an single to dual adapter in both my T1/DSD Pro but was curious in doing this myself but now that I know it’s possible in my DSD I will attempt these adapters in my T1. “Before you place the order for the 020302 adapter, contact Cimarron by email, and request the low profile, shoulderless pins - so the adapter sits low enough to fit in the DSD.” https://www.cimarrontechnology.com/product/browndog-020302-single-to-dual-op-amp-adapter Post #2565 ******* “I removed output caps and resistors, replaced transistors for Infineon...” Post #2450 @IvanTT can you source the Infineon transistors you replaced in the 3.5 stock DSD Pro, I’d like to do the same and also put some caps there as well! Not sure if the T1 has the same transitors but I’ll do the same and replaced them as well if it improves the audio signal and sensitivity! Thanks!
Thanks, Ivan! https://www.head-fi.org/threads/the-zishan-dsds-corner.826185/page-151#post-14845193 “Thanks! That seems like a fairly small space, to try to cram 2200uF in to. I found some low ESR 2200uF caps at Mouser, but they're BIG.” I found ones that fit in the DSD Pro but NOT in the T1. Improves the sound quality, sensitivity and VREF a lot! You'll need to use wire from some old aluminum caps but they do fit with ease in the DSD Pro! (See link below) https://www.mouser.com/ProductDetail/AVX/F750J228MMCAQ2?qs=gTYE2QTfZfQY3ykkl0/Suw== You can “short” the 3.5 outputs as well. It sounds more open. However, it can introduce unnecessary noise depending on the op amps (ultra low noise and distortion work best!) and how sensitive your iems are. (I ordered some jumper thin res film 0805 to make them more stable instead of soldered wire) Haven’t increased the ufs caps around the op amps up from 10ufs but this dude has been spot on with his mod recommendations! https://www.head-fi.org/threads/the-zishan-dsds-corner.826185/page-95#post-14688124 I have also thought about coupling film caps/wima around the 3.5 op amp socket in the DSD Pro and lieu of the 1.2 and 10 ohm resistors. But I'm not sure if this is possible just going on hunch based on designs/mods I've seem with this coupling?? Sadly, none of these modifications can be done on the T1 and I’m hoping the Ak4499 T1 isn’t this space restrictive to the DIY community- this would be an absolute disappointment.
SO. I do a super uber anti Hyper ultra GRUMPY Video review of the terrible ZISHAN T1! Hourray! Give a look at my youtube channel. (Parental Advisory: Crude langage)
Just ordered the T1. Anyone find a case for them? Hope they eventually move up to a capacitive touch screen in the future. Or someone makes a compatible one for modding. Any measurements of before and after mods?
