Probably. But I do not think it will be this month. Maybe next.
You can try Brainwavz S5. They are awesome.
These one is a good upgrade from ttppod t1e?
Thanks
Definitely! I own ZA Tenores and T1E. SQ on tenores is certainly better compared to T1E. While Duoza, as people here said is the best ZA IEM, is a level above. Simply said, duoza would be a very good upgrade over T1E.
T1E has plenty of bass but even tenores extend much deeper in sub bass territory. Also mids are kinda recessed on T1E, which are not a problem of ZA iems.
Just my opinion, please seek senior's thought as well if you want to have clearer idea.
So do the ZA bassos have greater sub bass quantity than the tenores?
And then do the duozas have even more sub bass than the bassos?
Yes I do like my sub bass lol! More so than mid bass. I had the T1E also and found the sub bass to be lacking but it was tight and detailed
Is ZA Duoza's bass quality better than the T1e's ?
