Eurobeat
- Aug 15, 2015
It could very well be a good thing. It is situation dependent .
Get used to them in stock form for a bit then see if you have any other pads you can pressure fit on top of the stock ones and see for yourself. this will be a cheaper attempt to see if it is for you.
As an example I have a set of rare Soviet orthodynamics that stock are rather in need of help, but adding a set of Creative pads on top of the thin stock ones completely transforms them to the point I don't feel the need to deal with a mod at all anymore.
Try a cheap pad stack first in case you don't like the approach. It won't be identical due to inner wall shape of the pad stack but it will approximate the effect. You'll then know one way or the other
Hmm.... I don't have any extra pads >(.
It seems the Alpha pads will work with the Pioneers also, so I'm going to get them. It seems they are super comfy, so I am going to try them out .
Hopefully I can sell them if I dislike them, but it seems I probably wont disliek them .
