ndburley
- Oct 28, 2014
That is an unfair comparison, as the Fiio X1 is around double the price of the Xduoo X2. Compare players that are similar in price. Compare the Xduoo X2 to the Fiio M3, and the Xduoo x3 to the Fiio X1.
Isn't the xDuoo X2 still much more powerful amp section compared to the Fiio M3? So still a pretty unfair comparison for the M3 besides the price being the same. They are much different players altogether only sharing a price bracket together. M3 has built-in memory and a puny amp meant for low impedance headphones while xDuoo X2 has no built in memory and a very powerful amp section.
Sorry the X2 is far away from a powerful amp section. The marketing specifications with 250 mW @ 32 ohms are absolute wrong.
In this complete independent reviews, both reviewers measured complete different values, instead of 250 mW @ 32 ohm in real world the X2 has around 39 mW @ 32 Ohm... It would be okay to have maybe only 240 mW in real world or so, but lol not only 39 mW instead of 250 mW, which are 211 mW difference, thats massive. In the 2nd review the M3 was measured too and this specifications are 100% correct with 30 mW @ 32 Ohm...
38 mW @ 32 Ohm: http://headphoniaks.com/blog/xduoo-x2-reproductor-sansa-clip-killer/2/
40 mW @ 30 Ohm: http://www.hifi-forum.de/viewthread-125-9627.html
The XDuoo X3 has been better compared to the Fiio X3 and said to be better in sound by some members than the X1 but the X1 has more bells and whistles. I would not compare everything on price.
http://www.head-fi.org/t/782912/xduoo-x3-dsd-24bit-192khz-cs4398-chip-lossless-music-player/105
I always have problem with classifying DAPs like that.
neglecting to talk about the headphone/IEM used for the sound comparison is really a great mistake IMO. no source is the best at everything for every headphones. it's just so unlikely that I really beg you guys to keep mentioning the headphone/IEMs tried with the DAPs when you make a judgment about which is better.
it's important to keep your posts in context, and it's important for others to get an incentive of what works and what might not. so please try to give your sound experiences for a complete sound system, not for a DAP alone. it really helps a lot.
This comparison has been made plenty of times and the X2 is better in sound quality but the X1 is better with UI.
The xDuoo X2 powers the 320 Ohm VE Zen pretty well except it needs to nearly max out to do so, but the FiiO X1 cannot do the same volume. Under load the X2 is significantly more powerful.
Can't seem to play flac 24Bit-96kHz on this. Anyone else having the same problem?
it wasn't aimed at you in particular but more at the last few posts trying to classify the DAPs.
even for consumer me, it helps me a lot to know what the guy used because if I have the IEM then I can better understand the motives and sometimes guess why something may or may not be for me without having to buy one ^_^.
this just contradicts 3 different sources of measurements ^_^.
if I can take a bet, I'd say you have the EQ ON for the X1 so the max output is 6db lower, making it 1.5v / 2. and that indeed is lower than the 1V of the X2. but not by much TBH.
now that's worth mentioning, but it's in itself a special case. by default the X1 will be like 2.5db louder when maxed out(not really a game changer ^_^).
please tell me if I was right. I've been wrong so many times in the last 2 weeks, I need some ego boost.
anybody else with both DAPs who could try please?
I would feel inclined to trust you over my measurements(that how confident I am when I do them^_^), because it's not like you have anything to gain from lying here. but my values fit headphoniaks, and those guys have real equipment for their tests(not like me) and do them into different loads. there is nothing to suggest that 300ohm would be different, the max voltage is very stable on both DAPs into different impedances.
maybe the max output was changed on one of the DAP with some firmware update? (I'm fishing here).
I can check the X1 with the latest FW but I have given the X2 to someone .
Talking about xDuoo X1 or FiiO X1?
