Sorry for activating his semi-dead thread, but is it true that the X2 is best suitable for cans and IEMs with more impedance? I mainly listen to my KZ ED9 and ATE, which are low ohm budget IEMs, and I was afraid that the X2 might overpower them and make them sound bad (eg. distorted bass, piercing highs).
SInce recently my Xduoo X3 died right now I have to fall back on X2 and besides the UI I have no fuss at all about this little guy.
Also, check what firmware version it comes with. I am running v7.0 2015_08_08 which sounds about right. Earlier versions had issues. I don't know is it's the latest, didn't bother to check.
Yes, v7.0 is the latest one. I'm running my x2 with v6.0 firmware. There were some rumours that v7.0 changes the output SQ. Better or worse I don't still know but I opted not to fiddle with it, I love it as it is.
So my xduo2 arrived, havent opened the box... just want to make sure, whats the best operating system to run? rockbox? stock ? update to most recent? leave it as is?
ATTENTION: To all who are frustrated with the random folder arrangement, there is a really easy solution to re-arrange all your folders alphabetically!
Press CTRL+F and it'll sort all your folders alphabetically when viewed inside the X2
Press CTRL+S to save [dunno if that's necessary]
You're done! Now all your folders (which I assume are your artists) will be arranged alphabetically!
So if you want to sort your folders alphabetically, get DriveSort.
P.S. Seeing that this software was mentioned only like 3-4 times in this thread, and seeing how often people complain about this (myself included), I believe that this is definitely something that should be mentioned again, if not many times again. I hope that this post was helpful to any future X2 owners out there, and hope that this will eventually pop up on Google when someone types in "how to sort songs alphabetically on XDuoo X2" or something like that.
