A quick after Xmas update - What I got for Xmas this year.
The 5 - E180CC Mullard tubes arrived at the local Post Office (From Great Britain), Dec 25th... sigh...
I had a nice surprise in an email from Xduoo Nov 27th:
"Hi, Hmscott
yes, thanks.
As a feedback, I can give you a TA-26, if you like it
Best Regards,"
I hadn't asked for anything, they simply offered it as thanks for my feedback. Of course, I said YES!!
I received the TA-26 on the 23rd and opened it yesterday evening...and here are my first impressions:
After digging through my headphone bags/boxes, I found my 6.35mm cables, removed the 4.4mm balanced cables, and tried out the TA-26 using the Topping D90 MQA.
At first it was "different", these are new tubes - they look like the standard China tubes Xduoo is famous for, and after swapping headphones around for a while:
Hifiman HE6SE V2, almost but not quite enough power - up to 80% on the TA-26 volume dial - The TA-20 delivers better power and experience.
Hifiman Ananda, wow, even at first play - I had to turn down the volume to 25% - the sound is full and encompassing, initially with some sharp tinges, but those went away after a few hours of listening.
Beyerdynamics DT770 Pro 16 ohm, that impedance is too low for the TA-26 - 60ohm-600ohm - so I'll try my DT880/600ohm and DT990/600ohm later and report back.
The Hifiman Ananda sounded so amazing on the TA-26 even with the stock tubes, that I didn't want to swap the Ananda out for any other headphones/IEM's. And, that was on movies (HBOMAX - Matrix Resurrections) and Youtube videos, but then when I listened on Tidal is when I was truly in appreciation of the TA-26 sound. The TA-26 SLAM! is unlike the TA-20, far more impactful and the "airy" sound I enjoy comes through on the Ananda's in excess to what I hear on the TA-20. And, that is with the stock tubes...
And, yes, of course I've already spec'd out a couple of new Mullard's for the TA-26, but before I pull the trigger on them does anyone with the TA-26 have any suggestions for tube pairings? I'll go back in this thread and start researching elsewhere for TA-26 tube ideas. I'll update here on what I find and enjoy.
Right when I thought I'd found the last tubes I'd need for my TA-20, Xduoo sucks me back in with the TA-26; I see what you did there.
Thanks to Xduoo for their kind gesture, and you can all be sure I'll not go too easy on Xduoo from here on out.
