sp3llv3xit
- Feb 8, 2013
Hi all,
Can someone point me towards the right direction to get 6FD7 tubes?
Thanks.
Don't tell me about all the cool equipment I have sold that I wish I hadn't. I ain't sellin my WA6, dammit.
Hi all,
Thanks.
Pay premium from Woo Audio if you want to be sure about the quality you are getting. They cost a lot though, 50 bucks for a pair I think, but again they do a thorough check, you'll be almost 100% if you buy from Woo.. If not buy like 3 pairs from a normal tube vendor for the same price, make sure you ask for matched pairs otherwise they might send you non matched. Oh and make sure you get fat tubes.
Thanks. I think I'll get them from Woo. Thanks.
''Oystein,
We purchase our tubes form a tube distributor then carefully select the highest quality of tubes and properly match them for the best sound.
We may have to go through a large number of poor tubes to arrive with the matched pair, so with the time and labor and number of tubes we reject we need to charge more to make a profit.
That is the reason our prices need to be higher. Thanks for the email and we fully understand if you choose to buy the tubes from another vendor.
We do appreciate your business and hope my explanation was acceptable.
Best regards,
Frank''
Probably the best, I know they check through a lot of tubes to find the "perfect" ones. Here is the mail from Frank:
So buy them with Woo if you want to be sure
That's the safer option. All the other stores don't have 6FD7s in stock, and eBay doesn't have matched pairs. I ended up going for 6SN7s for my WA6 lol.
Why are the tubes not among the products listed on their website?
http://www.wooaudio.com/products/
I just ordered a pair of 6FD7's from Woo, waiting for them too arrive.
I had a hard time finding them on their site also, but eventually went into every section I could and finally found them. Don't bother trying to find their tube (adapters) if you need them, you will not find them listed individually (without the tubes), you have to e-mail them for the just the adapters (without the tubes).
Tubes are listed under the upgrade options on the individual amp pages. The 6FD7s in particular are on the same page as the WA6-SE.
thought id post a pic of mine, which i picked up last week.
