Oh ok sorry for my wrongful conclusion.
Al D
Al D
@SilentOne (or anyone)
1) There are 3 pinXLR outputs for headphones on the back?
2) What's the benefit of making wa5 a dual Monoblock as opposed to separate PSU construction? What are tre the downsides?
Ardilla.
My amp is not balanced , it has 3 sets of RCA inputs and speaker terminals all on the rear of the amp.
On the front it has a 1/4 stereo headphone jack and a 4 wire XlR . Label k2 k or something like that . The XlR is for hi power headphones. Like the HE6.
1. No. The WA5 mono blocks are speaker amps only, no Headphone Outputs. I'm modifying these to have L/R 4-pin XLR Headphone Outputs for full mono K1000 Output functionality.
2. Pursuit. Though, simply splitting things up will likely add costs and nothing more. Mono blocks can provide the maker an opportunity to design a dedicated amp for a driver/speaker. Hopefully using better parts while in there, though that's not always the case. Also, monos make for shorter speaker runs. Some amps may/may not benefit from enhanced channel separation in mono config.
But this is a quick view from a speaker amp perspective. For headphones, doubtful. So, why do it? Pursuit. If there are ideals to be had, some people will chase. Despite lacking the ability to discern any differences.
Stay updated on Moon Audio at their sponsor profile on Head-Fi.
SO, why using a 4 pin XLR in each monoblock? You are going to be using just 2 pins on each. You can even use 1 TRS female connection on each one and will probably be easier and cheaper.
This is only suggested and neither final or critical really. My Headphone cable terminates with male 4-pin XLR plug. Once cabling leaves split from female 4-pin XLR adapter to amps, those terminations are left to choice. My wording is for illustration purposes only. I'm even considering 5-way binding posts instead. With current Wireworld pigtails, I wouldn't have to addany adapters or tips.![]()
Since you loose something by having AC transformer in the same chassis, have you considered a mono-vlock with dual external PSU's?? WA5-Mono four chassis version?![]()
