Could you define the things you are looking for more precisely? No?
Why ask then? This thread is going to be a dumping ground on amps that dont meet undefined and probably unrealistic criteria if they are ever defined. Congratulations for diluting head-fi. the amp-scape is currently a little thin, as many would agree: do we need more reasons for someone NOT to pursue their dream and build an amp?
Why not define the compromises you are willing to make, and go from there? Perhaps someone could help you find an amp that suits your tastes if you did that. Surely you must know that wire with gain as most people define it does not exist. Every time you improve one aspect of an amplifier, another suffers. You improve that, and something else is compromised. Its quite the vicious circle. You can easily end it by admitting to yourself what you are willing to compromise.
On a note at least as serious as the rest of this thread, I have built an amp that is by definition wire with gain.
I present to you the least-espressivo portable headphone amplifier:
As you can see it is a pair of transformers. There is nothing in the signal path except for a couple switches, a few bits of random wire, and the wire in the transformers.
Bandwidth on the low end of the bass is limited and the distortion at the low end is nothing to write home about. OTOH, the noise is exceptionally low, as is the output impedance. Both of which are critical in the application I put it together for. It is also wonderfully efficient, having run for several months without a battery.
Edited:
For fun I measured the transformers. I put these together about a year and a half ago, but never measured them. heh.
Into a 30 ohm resistor, 1.5v p-p input, 150mvp-p output. This will drive Ety ER4s to more than comfortable levels.
Bandwidth was about 30-100Khz -3db.
Phase shift was a few degrees from 15K-40Khz. I actually got tired of trying to see it.
10Khz squares looked quite nice, with slight sloping of the edges but NO overshoot. Compromises are what keep us sane.
Regarding the low-end extension of the transformers (or what some would call lack thereof): They start looking ugly around 25hz, and look positively ugly at around 15hz. Loosing the last half of an octave dosnt bother me.
