RPGWiZaRD
- Jan 31, 2010
I EQ all the time, any EQ will do, they all sound the same to me.
Either you must be deaf or then you've only used bad quality EQs (comparing only software EQs to each other, iTunes, foobar, winamp etc).
On iTunes I need roughly 3x bigger values/change to get somewhat similar sense of loudness curve: a ~1.5dB change on my hardware EQ represents ~4.5dB change on iTunes. The below settings sounds about as similar as possible:
