Ali89
- Jul 12, 2010
^, right side of the cable keeps breaking up unless you hold it the right way.
If you haven't done so, first make sure it is actually a problem with the cables by switching the earbuds from oneside to the other, and seeing if it still happens on the right cable. Once you determined it'snot a defect with the buds, you can buy Sleek Audio SA1 or SA6 cables. The SA6 cables enter at an odd angle, but I quite like them as they allow me to position the IEMs in a variety of comfortable positions and are substantially lighter, while also adding some needed length. They should be available for about $15 online.
