Chiho
- Apr 4, 2014
I'd say re-262
There's no best phones for vocal, it depends how you like your vocals. Whatever people suggest here is what THEY like, that might not be what you like.
Honestly if you are looking for smooth and forward vocals, I cannot recommend the Shure SE Balanced Armature line-up more (SE315 and above). The midrange on the SE line-up I would say is a class leader (for what you pay for, of course).
So far, Audio Technica IM02 is my pick! I love the outstanding, crystal clear vocal & just a little bass
However, while I've been waiting for it to be available at local store.
I'd like to ask you guys if there's any other interesting choices?
Like... UE900
or RE-400 (I've never tried this one, but heard it really rocks!)
Any suggestion? I'd like to try other choices before I make decision.
PS: a price is regardless.
Thanks in advance!
Stay updated on Noble Audio at their sponsor profile on Head-Fi.
If you want crystal clear vocals, and a little bass you really need to consider the Noble PR or the Noble FR.
The PR might be your first choice of the two.
Shure, customs are in a diffenent league, both in quality and price.
But for $700 one can get two separate high quality iem's, which is the same as having two-in-one, strictly from audiophilic point of view.
The FR and PR are essentially a "Two in one" IEM not a "two for the price of one" IEM.
From my experience, mid-forwardness is just not enough for vocals to sound as I like them to.
RE-262 is another mid-centric models rated on par or above Shure flagship SE535 for vocals.
But it was just too dark, veiled and soft for my liking. I guess 535 would be just the same, as it doesn't have a very pronounced treble. So, redrich2000 is right - it all depends on how you like your vocals, forward or laid-back, energetic or relaxed, clear or veiled, dark or sparky, etc.
