vhsownsbeta
- Jun 28, 2013
How do you cook a cable? This is a genuine question.
Well...apparently there are devices to do this; had no idea!
http://www.audioexcellenceaz.com/products/audiodharma-cable-cooker-cable-conditioner/
"Stereophile Recommended Component for 3 Years Running"
The good news is they're "Designed & manufactured in the U.S.A…built to last". They run anywhere from $999 to $1699 -- a pittance to pay to eek out that last nuance.
Of course, the other option would be to buy HD800/TH900/T1/Ether, etc. and wait for your cable to 'burn in' while listening to music (albeit in a slightly downgraded mode).
my eternal problem with all the usb magic boxes is a very basic idea: if something can consistently improve a DAC, why is it not inside the DAC already?just that should trigger a little skepticism.
I have 2 hypothetical answers:
1/ the guy who made the DAC doesn't know enough about the usb or whatever streaming protocol and requirements to use a design that isn't only good for laboratory conditions. or decided to cut corners to increase his margin.
the obvious reaction should be to get another DAC instead of trying to patch a poor design. right?
2/ the stuff you add that "improves" the sound, may only do so subjectively. <snip>
Stay updated on Schiit Audio at their sponsor profile on Head-Fi.
I do indeed have a factual based answer to #1 above, at least as applied to me: I have 7x the experience (35ish vs. 5ish years) design experience with DACs as opposed to USB interfaces. Therefore, I am at a lesser point on the USB learning curve. Since all of our DACs from Bimby up are upgradable, earlier adopters of our gear have been able to take advantage of USB upgrades as I have progressed along the learning curve. This enables our clients to avoid the much shorter haircut of a newer entire DAC, as opposed to a much less expensive upgrade board. It also enables a degree of freedom for both our customers and ourselves.
With respect to #2 above, I cannot comment, as there are too many system related factors dictating too many varietal scenarios upon which to comment.
On why such USB products exist, I have an observation to share. It seems there are a variety of differing performance level USB input DACs designed over the last several years. Combine this with the fact that both Mac and Windoze OS "upgrades?" seem to tolerate less and less current draw from their USB clients a they "progress" toward being compatible with smaller, harder to read and less current capability devices. A vital function of our own Wyrd magic USB box is to provide much more current to the USB based DAC.
But why would one need more than single Wyrd in a chain?
As I see it these "usb magic boxes" we are exploring, are revealing were changes in design can take us, for better and for worse.
And most of our experiments are trial and error attempts to push the envelope and discover what happens when the the limits of what is 'known' are exceeded.
To dismiss these efforts out of hand is, in my opinion, missing the point and just promotes the status quo of 'good enough' thinking.
And while for some 'good enough' is just dandy, others will want/need/must push the limits of what is possible, firstly to know what IS possible, then to know how much of an improvement IS possible, so to come to understand more of the 'big picture', while not getting bogged down by the minutia.
As for the attitude that these efforts are unworthy of spending our time investigating them, well, I'm reminded of a quote from long ago.
“There is a principle which is a bar against all information, which is proof against all arguments, and which cannot fail to keep a man in everlasting ignorance—that principle is contempt prior to investigation.” Rev. William H. Poole 1879
And another that seems to apply here to is…
"Awareness leads to recognition, recognition leads to desire, desire leads to manifestation, manifestation leads to observation of what was generated - and the cycle of evolution begins a new." Author unknown
And lastly these variations upon a common theme…
"Never doubt that a small, group of thoughtful, committed citizens can change the world. Indeed, it is the only thing that ever has."
Margret Mead
and
"A new scientific truth does not triumph by convincing its opponents and making them see the light, but rather because its opponents eventually die, and a new generation grows up that is familiar with it."
"Truth never triumphs — its opponents just die out."
"Science advances one funeral at a time." Max Planck
Lastly,
It is not hard to find Truth. What is hard is not to run away from it once you have found it.
- Prometheus
JJ
