Thanks, Landroni. I definitely won't be bullied into the "no-diff/sound science" camp. If that was the case, I wouldn't own some of the equipment I own (i.e. multibit DACs and Tube Amps).
Regarding the electrical noise thing, I get the concept and have dealt with this issue in the past but don't currently have those issues to any discernible degree in my systems. Even so, I've given thought to buying a Wyrd to see if it could make an audible difference; for $100, why not? Hmmm, maybe some Nordost cables would help as well?!
Regarding timing/jitter errors, isn't this what 'Asynchronous' is supposed to fix -- assuming, of course it's well implemented?
Now on Error Correction...this actually sounds like there
could be differences that
might be discernible. That said, it should also be easily measurable (bits in = bits out) between brands/models of PC's/components. If this were the case, then it would make sense to choose a specific PC brand/component.
That said, my understanding is that many DACs have bi-directional communication and error correction built into them to ensure that uncorrupted, bitperfect data transfer does occur. Some manufacturers tout this capability including Schiit...
"Advanced Clock Management, USB Input Standard -- Bifrost uses a sophisticated master clock management system
to deliver bit-perfect data to the DAC—unlike many DACs that use asynchronous sample rate conversion (ASRC), which destroys the original samples. And, with our acclaimed Gen 2 USB input now standard, you’re ready for computer, tablet, and even phone-based sources."
If Schiit's statement is true, doesn't it really boil down the the DAC/AMP combo at that point -- not the PC (assuming electrical noise isn't an issue)?
On the 'trust my ears' front, I'd buy a high-end set of Beats if I thought they sounded better than my other headphones. :eek:
