johnjen
With the MultiBit dacs, you will hear what the recording has to offer.
Meaning the degree of resolution and complexity you will hear is based upon the source file itself.
And yes these dacs are 'best' with 'natural' instruments vs 'synthetic' instruments (all electronic, no direct acoustical connection when recorded)
That isn't to say all electronic tracks don't work well, but they usually have VERY different resonance and harmonic patterns, which don't resemble room acoustics much at all.
IOW if the recording is 2nd rate, or worse, that is what you'll hear.
And likewise if it's a killer recording, That is what you'll hear as well.
This is one way of 'explaining' what the MB dacs bring to the table.
For instance, if they used a really good mic and positioned it properly and used really good electronics to record the single guitar etc, then you will be in for a treat.
Assuming of course the rest of your system is on par.
And if you can't hear any difference between those 2) MB dacs, then that certainly kills off any attack of audio nervosa, huh?
The next question is, does it sound good to you, and if so enjoy the music!
JJ
JJ
