ColtMrFire
- May 30, 2010
I'm not getting a Valhalla. But I will look into those tubes. Which brand?
For a lay person, what's the best way to test tubes to see if they're bad? Back in the day you could take it to a hardware store but unfortunately those times have gone away.
RE Tube life - I really have not studied this topic to be able to comment authoritatively; that said, I do have quite a bit of experience with tubes over the last 50 years or so as a user. That experience tells me that (power tubes aside)they tend to have quite a long life, much more so than I expected. My experiences with 6DJ8ish tubes over the last 40 years or so tell me they seem to last at least 5 years or so of hard life, before replacing them reveals that the older ones are beginning to sound like ass. Power output tubes (EL34, 6550, 6L6, 2A3, 300B, etc.) seem to be shorter, with 2 years or so of the same hard use life.
I just found a textbook from the 1940's that deals with tube design. NOT design with tubes, but how to design vacuum tubes themselves. More will be revealed as the book is already in my bathroom.
ahh, so that's where these schiity ideas come from!
You've promised never to release a server. Can you make that same promise on tubes?
Stay updated on Schiit Audio at their sponsor profile on Head-Fi.
That's a derivative of the float test.
If it sinks it was bad, if it floats, well, you're free to go get it…
JJ
JJ
Isn't that the test for witches? Didn't know it worked for tubes, too.
