Baldr
Sponsor: Schiit Audio
- May 14, 2011
So, here they are:
1) Is this (megacomboburrito) filter exactly the same once found in the Theta Digital D/A converters? Or is the Schiit one a more refined, better optimized version (or evolution) of that one?
2a) If the Schiit filter is a more refined version of the Theta filter (I understand that the two would be conceptually more similar than different, in any case), is this because you managed to refine it recently or you already had it available and 'perfected' at the time, but you couldn't implement it due to (for example) hardware constraints back then?
2b) [closely related] In this latter case (i.e. if Theta digital filter was the same as Schiit's current one), should you have had a more powerful DSP processor than that Motorola one at that time, do you feel the digital filter section of the Theta DACs designed by you would be the same as the Schiit multibit DACs?
1. The Schiit filter is a revised and updated version of the original Theta filter.
2. There were hardware constraints which limited the original Theta filter as well as some new parameter changes developed since the Theta.
Stay updated on Schiit Audio at their sponsor profile on Head-Fi.
