jussssss
- Jun 22, 2009
bakhtiar have you tried them with a D2? im using them with a D2 now but i tried the x1050 (without um3x ) but thought it sounded more fun than a D2
Originally Posted by jussssss /img/forum/go_quote.gif bakhtiar have you tried them with a D2? im using them with a D2 now but i tried the x1050 (without um3x ) but thought it sounded more fun than a D2 |
Originally Posted by sennmann /img/forum/go_quote.gif how is the um3x in comparsion to the w3? are the mids more pronounced? is there a little bit less bass? the w3 offers a lot of it? and how are the highs exactly as good as in the w3? |
Originally Posted by pomme de terre /img/forum/go_quote.gif Anyone in Toronto (around UofT St George or in Scarborough) with a pair of UM3X or W3's that would like to give my pair a listen to see if they sound the way they should, or would let me give their pair a brief listen? Thanks in advance! |
Originally Posted by nc8000 /img/forum/go_quote.gif Cable microphonics is essentially non existing on the Westone cables. I haven't tried mine outdors yet so don't know about wind noise but with the super low profile fit I would guess that there is going to be very little of that as well. Physical comfort to me is very good but I could imagine that somebody with small ears might have trouble fitting them inside the outer ear, the only problem I have is that since it can't go very deep in the ear I sometimes don't feel that I get as good a seal as I do with my Etymotics phones so I'm waiting for some large olives to turn up. |
Originally Posted by turnstyle /img/forum/go_quote.gif The UM3x doesn't have a ridge on the stem that holds the tips, right? Can you slide your tips a bit further out on the stem to get a better fit? |
Originally Posted by turnstyle /img/forum/go_quote.gif It would also be great if you can possibly help compare the UM3x to other high-end universal IEMs with respect to comfort, micorphonics, and wind noise -- ie, setting aside the "my preferred signature" type questions, and more about the physical attributes. |
Originally Posted by nc8000 /img/forum/go_quote.gif No there are no ridges to hold on to the tip so they really need to be pushed all the way down. I had used my standard spacer mod like I do on the Etymotics phones and that helped since the olive got a little further into the ear but more often than not I was left with the tip inside the ear when I took the phones out |
Originally Posted by Spyro /img/forum/go_quote.gif Actually W3 stems are a bit shorter which has led to more fit problems. |
